[geos-devel] Small gaps between results of GEOSDifference?
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Fri Feb 15 08:33:53 PST 2013
Hi Sandro
Thanks for explaining this. In the short term, it seems best to me to
always enable 'topological editing' in QGIS together with avoid
intersection. That way, the intersection vertices are added to both
geometries.
>Exposing fixed precision to the C-API is on the TODO list for 3.1 so if
>you want to help with that you're very welcome. It will take exposing
>a new PrecisionModel abstract class and provide means to attach them to
>GEOSGeometry objects.
So basically the subclass of PrecisionModel will do the rounding? Looks
like a very clean approach to me, I'm looking forward to the new version.
Regards,
Marco
On 15.02.2013 17:02, Sandro Santilli wrote:
> On Fri, Feb 15, 2013 at 02:40:16PM +0100, Marco Hugentobler wrote:
>>> If you want to further
>>> debug your case you may try to build geos yourself with uncommenting
>>> the GEOS_DEBUG_BINARYOP define in include/geos/geom/BinaryOp.h and
>>> see what happens to each operation.
>> Ok, the output from the program is now:
>> Trying with original input.
>> POLYGON ...
>> POLYGON ...
>> Does 'Trying with original input' mean there are no robustness issues?
> It means no exception has been thrown.
> So the problem is NOT with the heuristics in BinaryOp.
> After taking a look at the geometries I now know what's going on.
> The two very simple (almost rectangle) polygons overlap so that
> their boundary intersect at exactly 2 points.
> Those 2 points are NOT vertices in the input geometries, so when
> constructing a geometry resulting from an overlay (be it union
> or difference) a vertex is added to the boundary producing a
> slight modification of the so-splitted segment.
> This is expected and unavoidable with finite precision.
> In the A + B case all geometries take part to the build of a single
> topology, so the intersection points become vertexes of the single
> output geometry.
> In the A + ( B - A ) instead there are two different topologies
> being built. First topology (B-A) is built the same way as (B+A)
> would be built, produces the same vertices and gives you back
> a polygon with those two additional vertices that are NOT NECESSARELY
> found on the segment they did split.
> The second topology building phase (A + (B-A)) finds one of those
> two vertices is NOT on the line, and so does not generate noding at
> that specific point.
> I see two possible solutions to this problem:
> 1. Use arbitrary precision
> 2. Use controlled fixed precision
> GEOS doesn't implement 1, and I don't think that's generally a good solution.
> Fixed precision _is_ implemented BUT not exposed to the C-API yet.
> What you could do, as a workaround, is explicitly snapping the geometries
> each other to a tolerance of choice. That way geometry A would snap to
> the new node - now being a vertex of (B-A) - and topology builder would
> node them consequently.
> See also: http://trac.osgeo.org/postgis/wiki/ToleranceDiscussion
> --strk;
> http://www.cartodb.com - Map, analyze and build applications with your data
> ~~ http://strk.keybit.net
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
