[geos-devel] [GEOS] #609: GEOSPointOnSurface returns EMPTY for single-point linestring
geos-trac at osgeo.org
Fri Jan 11 06:01:58 PST 2013
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.7
Component: Default | Version: 3.3.6
Severity: Unassigned | Keywords:
Comment(by strk):
So for GEOSCentroid the answer is correct, in that by definition the
CentroidLine class computes the centroid of all segment's midpoint
weighted by segment length, so a zero-length segment is not considered.
Now, the algorithm of InteriorPointLine [1] is:
- Find an interior vertex which is closest to the centroid of the
linestring.
- If there is no interior vertex, find the endpoint which is closest to
the centroid.
[1]
http://www.vividsolutions.com/jts/javadoc/com/vividsolutions/jts/algorithm/InteriorPointLine.html
But if there's no interior vertex both endpoints are equidistant to the
centroid, aren't them ?
Martin: am I missing anything ?
Ticket URL: <http://trac.osgeo.org/geos/ticket/609#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
