[geos-devel] [GEOS] #610: geos 3.3.6 : WKTReader fails on POINT(0 0) (MSVC 2008, W7)
GEOS geos-trac at osgeo.org
Fri Jan 11 06:37:42 PST 2013
 Reporter:  gt75        |        Owner:  geos-devel@…
     Type:  defect      |       Status:  closed
 Priority:  major       |    Milestone:  3.3.7
Component:  Default     |      Version:  3.3.6
 Severity:  Unassigned  |   Resolution:  worksforme
 Keywords:              |
Changes (by mloskot):
  * status:  new => closed
  * resolution:  => worksforme
Comment:
 My crystal sphere failed to figure out what you mean by "//HERE IT FAILS",
 but the tests confirm everything is in order and the mysterious failure is
 not reproducible r3740
Ticket URL: <http://trac.osgeo.org/geos/ticket/610#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
