[geos-devel] [GEOS] #615: ST_SymDifference triggers a crash in WKTWriter (?)
geos-trac at osgeo.org
Wed Jan 16 07:30:44 PST 2013
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.3.7
Component: Default | Version: 3.3.6
Severity: Unassigned | Keywords:
For some obscure reason computing the SymDifference between the geometries
showed in here: http://trac.osgeo.org/postgis/ticket/2177
Results in a crash deep in WKTWriter (which should be unrelated).
There could be some bogus debug line around...
Ticket URL: <http://trac.osgeo.org/geos/ticket/615>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
