[geos-devel] [GEOS] #616: Build failure with VS2012
GEOS geos-trac at osgeo.org
Fri Jan 25 08:47:08 PST 2013
 Reporter:  jluis       |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.7
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
 Using cmake and VS2012 fails with
 C:\programs\compa_libs\geos_SVN\src\operation\buffer\BufferOp.cpp(91) :
 error C2589: '(' : illegal token on right side of '::'
 error C2059: syntax error : '::'
 it also prints the following warning (I think it didn't when I tried to
 build version 3.3.5)
 C:\programs\compa_libs\geos_SVN\include\geos/precision/GeometryPrecisionReducer.h(154)
 : warning C4512: 'geos::precision::GeometryPrecisionReducer' : assignment
 operator could not be generated
 C:\programs\compa_libs\geos_SVN\include\geos/precision/GeometryPrecisionReducer.h(42)
 : see declaration of 'geos::precision::GeometryPrecisionReducer'
Ticket URL: <http://trac.osgeo.org/geos/ticket/616>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
