[geos-devel] [GEOS] #616: Build failure with VS2012
GEOS geos-trac at osgeo.org
Fri Jan 25 09:09:05 PST 2013
 Reporter:  jluis       |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.4.0
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
Comment(by jluis):
 Sorry for the wrong milestone. It was already set to 3.3.7 and I didn't
 notice.
 No, I didn't try 3.3.7 as I am using the trunk version (r3754).
 BTW, I changed 'std::max' to 'max' and the build continued much further
 but still failed with
 C:\programs\compa_libs\geos_SVN\capi\geos_ts_c.cpp(97) : fatal error
 C1083: Cannot open include file: '../geos_svn_revision.h': No such file
 or directory
Ticket URL: <http://trac.osgeo.org/geos/ticket/616#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
