[geos-devel] [GEOS] #616: Build failure with VS2012
geos-trac at osgeo.org
Fri Jan 25 09:40:11 PST 2013
Reporter: jluis | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.4.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Resolution: wontfix
Keywords: |
Comment(by jluis):
Sorry, 'wontfix' why?
Issue #556 refers to the non generating of the geos_svn_revision.h file
but this ticket is about error at line 91 of BufferOp.cpp which has
nothing to do with the header file.
Ticket URL: <http://trac.osgeo.org/geos/ticket/616#comment:6>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
