[geos-devel] [GEOS] #616: Build failure with VS2012
GEOS geos-trac at osgeo.org
Fri Jan 25 10:01:34 PST 2013
 Reporter:  jluis       |        Owner:  geos-devel@…
     Type:  defect      |       Status:  closed
 Priority:  major       |    Milestone:  3.4.0
Component:  Default     |      Version:  svn-trunk
 Severity:  Unassigned  |   Resolution:  wontfix
 Keywords:              |
Comment(by mloskot):
 @jluis
 First, instead of changing ''std::max'' you should fix your build
 configuration on Windows as this issue is related to buggy headers on
 Windows. So, use ''#define NOMINMAX'', etc. Seek for details on MSDN.
 Second, regarding ''geos_svn_revision.h'', I updated the CMake wiki pages
 to indicate these files should be created manually:
 [wiki:BuildingOnWindowsWithCMake] and [wiki:BuildingOnUnixWithCMake].
Ticket URL: <http://trac.osgeo.org/geos/ticket/616#comment:9>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
