[geos-devel] [GEOS] #590: GEOSBufferWithStyle result isn't valid and GEOSIsValid() says it is
GEOS geos-trac at osgeo.org
Sun Jan 27 23:45:10 PST 2013
 Reporter:  olivier80   |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.x
Component:  Default     |     Version:  3.3.5
 Severity:  Unassigned  |    Keywords:
Comment(by Olivier80):
 No, I attached a second image showing that outer ring is self crossing by
 moving slightly one point to the left. This "hole" is there in the image
 because the winding number is 2 in it.
 Anyway, the buffer of the input linearing should not be what we see in the
 first image.
Ticket URL: <http://trac.osgeo.org/geos/ticket/590#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
