[geos-devel] [GEOS] #602: GEOSOffsetCurve: IllegalArgumentException: RobustDeterminant encountered non-finite numbers
geos-trac at osgeo.org
Mon Jan 28 06:32:10 PST 2013
non-finite numbers
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.x
Component: Default | Version: 3.3.6
Severity: Unassigned | Keywords:
Comment(by strk):
NOTE: the same error occurs when passing a zero-length line to the
function. Taking 5.6e-05 the same as zero may or may not be a solvable
bug. I wonder if JTS survives this one.
Ticket URL: <http://trac.osgeo.org/geos/ticket/602#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
