[geos-devel] [GEOS] #602: [JTS works] GEOSOffsetCurve: IllegalArgumentException: RobustDeterminant encountered non-finite numbers
GEOS geos-trac at osgeo.org
Tue Jan 29 19:53:03 PST 2013
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.x
Component:  Default     |     Version:  3.3.6
 Severity:  Unassigned  |    Keywords:
Comment(by mdavis):
 The same result as if the zero-length line was a point.
Ticket URL: <http://trac.osgeo.org/geos/ticket/602#comment:7>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
