[geos-devel] [GEOS] #459: Union fails to fully node input linework
GEOS geos-trac at osgeo.org
Tue Jul 2 14:01:12 PDT 2013
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.4.0
Component:  Default     |     Version:  3.3.0
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 I shall check if snaprounding works for those two failing cases now that
 the HotPixel bug has been fixed with r3825. Let's keep it.
Ticket URL: <http://trac.osgeo.org/geos/ticket/459#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
