[geos-devel] GSoC '13 Weekly Report 3- Adding Voronoi Diagram to GEOS
Sandro Santilli
strk at keybit.net
Mon Jul 8 09:24:38 PDT 2013
Vishal, I've noticed you're doing your work into an isolated
repository [1]. Instead I think it'd help if you could do it
directly within a fork of the original repository [2].
That way it'll be easier for other developers to follow progress
and test changes as early as possible in the process.
[1] https://github.com/vishaltiwari/GSoC-GEOS
[2] https://github.com/libgeos/libgeos/
--strk;
On Fri, Jul 05, 2013 at 07:18:28PM +0530, vishal tiwari wrote:
> Hi,
> *1. Work Done:*
> - Came across with some more methods related to VoronoiDiagram in other
> class and also ported them.
> - Completed the port of VoronoiDiagramBuilder.
> *2. Problems Faced :*
> - No problems faced as such.
> *3. Work to be done in the next week:*
> - Write C++ testcases for QuadEdgeSubdivision class
> and VoronoiDiagramBuilder class.
> Regards,
> Vishal Tiwari
> Undergraduate
> Computer Science and Engineering
> Lab for Spatial Informatics
> IIIT-Hyderabad
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
http://www.cartodb.com - Map, analyze and build applications with your data
~~ http://strk.keybit.net
