[geos-devel] Getting Parse Exception
vishal tiwari
hi.vishal123 at gmail.com
Wed Jul 10 13:15:51 PDT 2013
I am referring ParseException: Expected number but encoundered ','''. This
error comes when i run my test case.
My second problem i as:
- mytest.cpp:(.text+0xf): undefined reference to
> > > `geos::io::WKTReader::WKTReader()'
This error comes when i try to use any geos header files, in some other
program.
On 11 July 2013 01:38, Sandro Santilli <strk at keybit.net> wrote:
> On Thu, Jul 11, 2013 at 01:35:28AM +0530, vishal tiwari wrote:
> > I have already added VoronoiTest.cpp in tests/unit/Makefile.am , and run
> > autogen and configure. Still i am facing the same problem.
> The problem you reported was:
> Which doesn't seem like coming from a `make geos_unit`.
> Or are you referring to:
> > "ParseException: Expected number but encountered ','"
> --strk;
> > On 11 July 2013 01:30, Sandro Santilli <strk at keybit.net> wrote:
> > > On Thu, Jul 11, 2013 at 12:59:05AM +0530, vishal tiwari wrote:
> > > > I was making test case for VoronoiDiagramBuilder [1] , but got this
> > > > following exception:
> > > > group: geos::triangulate::Voronoi, test: test<1>
> > > > problem: unexpected exception
> > > > exception typeid: N4geos2io14ParseExceptionE
> > > > message: "ParseException: Expected number but encountered ','"
> > > > Is it not able to parse the string data that i have passed? Or the
> error
> > > in
> > > > the implementation of VoronoiDiagram? If its not in the
> VoronoiDiagram
> > > > code, then how do i fix it?
> > > > [1]
> https://github.com/vishaltiwari/libgeos/blob/svn-trunk/tests/unit/triangulate/VoronoiTest.cpp
> > > It is unable to parse the string data you have passed.
> > > Indeed you're using a comma between X and Y ordinate values of each
> point
> > > in the MULTIPOINT geometry.
> > > > Also, i was trying to use the C++ wrapper, directly in order to test
> my
> > > > code, in some "file.cpp", and after including the necessary header
> > > files, i
> > > > am getting errors like:
> > > > - mytest.cpp:(.text+0x58): undefined reference to
> > > > `geos::io::WKTReader::read(std::basic_string<char,
> > > std::char_traits<char>,
> > > > std::allocator<char> > const&)'
> > > > I think this might be some linkage problem or something like that.
> How
> > > do i
> > > > directly use the header files that are defined.
> > > You need to add "VoronoiTest.cpp" to tests/unit/Makefile.am
> > > then run ./autogen.sh from the top-level dir and ./configure again.
> > > Then you build with:
> > > cd tests/unit
> > > make geos_unit
> > > --strk;
> > Vishal Tiwari
> > Undergraduate
> > Computer Science and Engineering
> > Lab for Spatial Informatics
> > IIIT-Hyderabad
> > geos-devel mailing list
> > geos-devel at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geos-devel
> http://www.cartodb.com - Map, analyze and build applications with your
> data
> ~~ http://strk.keybit.net
Vishal Tiwari
Undergraduate
IIIT-Hyderabad
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130711/3f9bd5c9/attachment-0001.html>
