[geos-devel] Weekly Report 4 - Adding Voronoi Diagram to GEOS
vishal tiwari hi.vishal123 at gmail.com
Fri Jul 12 23:20:17 PDT 2013
Hey,
My week 4 report is as follows:
*1. Work Done:*
   - Tested some methods in geom::Triangle and geom::CoordinateList that
   were ported and also tested some methods of VoronoiBuilder class.
   - A lot of time was spend in fixing bugs and memory leaks.
*2. Problems Faced:*
   - As its a port from java to C++, we have to take care for memory leaks.
   So i had some troubles in resolving them. Also i am stuck in a comparison
   between two QuadEdge objects, which i am working out with strk, and will be
   resolved soon.
*3. Work to be done in the next week:*
   - Deal with the problem i am facing and write test cases for the
   remaining methods.
Thanks and kind Regards,
Vishal Tiwari
Undergraduate
Computer Science and Engineering
Lab for Spatial Informatics
IIIT-Hyderabad
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130713/77f4b91a/attachment.html>
