[geos-devel] Comparing two QuadEdge objects
vishal tiwari
hi.vishal123 at gmail.com
Sun Jul 14 05:40:21 PDT 2013
hey,
just figured out, that it's a pointer check. It's going to an infinite loop
because of some error in previous function call.
Thanks,
Vishal
On 13 July 2013 11:57, vishal tiwari <hi.vishal123 at gmail.com> wrote:
> Hey strk,
> I tried to compare them my pointers as: qe != (QuadEdge*)&startQE, but
> this condition is always true and goes into an infinite loop.
> On 13 July 2013 11:43, Sandro Santilli <strk at keybit.net> wrote:
>> On Fri, Jul 12, 2013 at 08:52:24PM +0530, vishal tiwari wrote:
>> > This part of code in getVoronoiCellPolygon, :
>> > QuadEdge startQE = qe;
>> > do {
>> > // Coordinate cc = circumcentre(qe);
>> > // use previously computed circumcentre
>> > Coordinate cc = qe.rot().orig().getCoordinate();
>> > cellPts.add(cc);
>> > // move to next triangle CW around vertex
>> > qe = qe.oPrev();
>> > } while (qe != startQE);
>> > The while condition is comparing two QuadEdge objects for not being
>> equal.
>> > So i need to override the != operator. How do it do it?
>> I suspect that's a by-ref check, can you verify ?
>> Linking between QuadEdges are by pointer, aren't them ?
>> --strk;
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
> Vishal Tiwari
> Undergraduate
> Computer Science and Engineering
> Lab for Spatial Informatics
> IIIT-Hyderabad
Vishal Tiwari
Undergraduate
IIIT-Hyderabad
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130714/bb2c4455/attachment.html>
