[geos-devel] vector::_M_range_insert error
vishal tiwari
hi.vishal123 at gmail.com
Wed Jul 17 00:23:32 PDT 2013
Hey,
I am having a problem while return a Polygon pointer from getVoronoiPolygon
to getVoronoiPolygons in [1]. When i print Coordinates of a Polygon, just
before returning it, its shows me the correct values, but doesn't work if i
print the same coordinates using the returned polygon. It gives the
following error:
terminate called after throwing an instance of 'std::length_error'
what(): vector::_M_range_insert
Aborted
I am stuck in it for a long time. Any clues on how i can fix it?
[1]
https://github.com/vishaltiwari/libgeos/blob/svn-trunk/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
Thanks,
Vishal
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130717/63cae4a4/attachment.html>
