[geos-devel] [GEOS] #602: [JTS works] GEOSOffsetCurve: IllegalArgumentException: RobustDeterminant encountered non-finite numbers
geos-trac at osgeo.org
Wed Jul 17 07:38:41 PDT 2013
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.9
Component: Default | Version: 3.3.6
Severity: Unassigned | Keywords:
Comment(by strk):
The problem seems to originate in an attempt by OffsetegmentGenerator to
compute the offset of a zero or close-to-zero length segment, which
results in a NaN ordinate offset.
I guess it could be worked around this by omitting the zero or too-short
segment from the list (I'm surprised this isn't done already by the
simplification step).
Ticket URL: <http://trac.osgeo.org/geos/ticket/602#comment:8>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
