[geos-devel] [GEOS] #638: Recommend a static_cast around assert strings
geos-trac at osgeo.org
Thu Jul 18 12:25:57 PDT 2013
Reporter: goatbar | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.3.8
Severity: Unassigned | Keywords:
I recommend that for all asserts with strings, that they be changed to
wrap the string in a static_cast. Not very exciting, but it makes the
stricter compilers happier.
e.g. in src/geom/util/GeometryEditor.cpp
assert(!"SHOULD NEVER GET HERE");
changes to
assert(!static_cast<bool>("SHOULD NEVER GET HERE"));
Ticket URL: <http://trac.osgeo.org/geos/ticket/638>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
