[geos-devel] Voroni project accepted for GSoC '13
Sandro Santilli strk at keybit.net
Fri Jun 14 00:10:21 PDT 2013
On Thu, Jun 13, 2013 at 11:48:51PM +0530, vishal tiwari wrote:
> Hey,
> I have setup the wiki page here: http://trac.osgeo.org/geos/wiki/GSoC. It
> contains the link to the page, where the weekly reports will be present and
> a link to the git hub repository. I will also be sending the weekly report
> to the geos mailing list.
> I have been reading the geos documentation and have seen the last port of
> DelaunayTriangulation. I have seen the code of VoronoiDiagramBuilder of
> JTS. And have figured out the classes that needs to be ported. I will be
> the porting the missing  quadedge subclasses and methods during the first
> week.(17th June - 22nd June)
Thanks for the heads-up, Vishal.
Don't hesitate to ask any question that might arise on this list.
Please check if JTS has any unit test to port for each of the classes
you're working on, and consider building your own if not.
--strk;
