[geos-devel] MULTI* and Invalid
Oliver Courtin olivier.courtin at oslandia.com
Fri Jun 14 10:55:45 PDT 2013
Le 14 juin 2013 à 17:09, Martin Davis a écrit :
> The relevant section of the OGC SFS spec (99-049) is 2.1.11 MultiSurface:
> "The boundaries of any two elements in a MultiSurface may intersect at most at a finite number of points"
> An intersection which is a line segment contains an infinite number of points, so this is invalid.
Thanks both Martin and Sandro for this clear answer !
O.
