[geos-devel] [GEOS] #634: geos_svn_revision.h being regenerated with bad one
geos-trac at osgeo.org
Wed Jun 19 22:42:38 PDT 2013
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone: 3.4.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
I'm not sure what triggers this but on my mingw64 builds the revision
number is always being overwritten with 0. I built from tar ball this
time and it still insists on trying to pull from svn when I'm building
with CMake and then overwrite the good packaged
geos_svn_revision.h (that has a number with 0)
Is there a way to turn this off or have it not do it when you are building
from tar ball?
Ticket URL: <http://trac.osgeo.org/geos/ticket/634>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
