[geos-devel] Weekly Report 2 - "Adding Voronoi Diagram to GEOS"
vishal tiwari
hi.vishal123 at gmail.com
Fri Jun 28 11:55:55 PDT 2013
*1. Work Done:*
- I have fixed the problems that i was facing the previous week.
- I have ported all the methods and classes that are required
for VoronoiDiagramBuilder.
- I have started the port of VoronoiDiagramBuilder class.
*2. Problems Faced :*
- During the port of one of the methods i was stuck with some C++ STL
data structure, which required a different compiler, but it was solved, as
i used a different STL data structure. It was not much of an issue.
*3. Work to be done in the next week:*
- Finish the port of VoronoiDiagramBuilder class.
- Write the testcases for QuadEdgeSubdivision class, and related methods
that i have ported earlier.
Report link: http://trac.osgeo.org/geos/wiki/Reports#Week2Report
Regards,
Vishal Tiwari
Undergraduate
Computer Science and Engineering
Lab for Spatial Informatics
IIIT-Hyderabad
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130629/aa24072f/attachment.html>
