[geos-devel] [GEOS] #554: Artifacts and limitations of bufferLineSingleSided
geos-trac at osgeo.org
Sun Jun 30 14:29:35 PDT 2013
Reporter: ylan | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.4.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
Changes (by robe):
* cc: ylan (added)
Comment:
Are you still having issue with this? Looks fine to me with my latest
GEOS 3.4. under PostGIS 2.1.
SELECT ST_OffsetCurve(wkb,3);
original in center
SELECT ST_OffsetCurve(wkb, -3);
See attached openjump image
Ticket URL: <http://trac.osgeo.org/geos/ticket/554#comment:7>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
