[geos-devel] [GEOS] #625: Ruby
GEOS geos-trac at osgeo.org
Tue Mar 12 09:04:21 PDT 2013
#625: Ruby
 Reporter:  stuporglue  |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
 I tried to build with --enable-ruby, but the generated Makefiles are
 broken with
 "Makefile:237: *** missing separator.  Stop."
 The problem is in /macros/ruby.m4, line 41. It has "puts puts". This
 generates a line with "nil" on it in the Makefiles.
 RUBY_SO_NAME=`$RUBY -rrbconfig -e 'puts puts
 RbConfig::CONFIG[["LIBRUBY_SO"]] || Config::CONFIG[["RUBY_SO_NAME"]]'`
 Switching that to a single "puts" lets the Makefile be generated
 correctly.
Ticket URL: <http://trac.osgeo.org/geos/ticket/625>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
