[geos-devel] using CoordinateOperation::edit cause memory leaks
Tereza Fiedlerová
tfiedlerova at gmail.com
Wed May 8 04:59:28 PDT 2013
Hello,
I'm trying to edit Geometry using class CoordinateOperation. My
implementation of CoordinateOperation::edit function looks like follows:
CoordinateSequence* VertexGeometryEditorOperation::edit(const
CoordinateSequence *, const Geometry *geom )
CoordinateSequence* coord = geom->getCoordinates();
for ( size_t i = 0; i < coord->getSize(); i++)
coord->setAt( closeCoord->getAt(i)+number, i );
return coord;
Everything works fine, but when I check it with walgrind it returned these
memory leaks:
==19845== 168 bytes in 3 blocks are possibly lost in loss record 335 of 426
==19845== at 0x4C2C154: operator new(unsigned long)
(vg_replace_malloc.c:298)
==19845== by 0xF206682:
geos::geom::GeometryFactory::createLinearRing(geos::geom::CoordinateSequence*)
const (GeometryFactory.cpp:411)
==19845== by 0xF211A31:
geos::geom::util::CoordinateOperation::edit(geos::geom::Geometry const*,
geos::geom::GeometryFactory const*) (CoordinateOperation.cpp:38)
==19845== by 0xF2123D6:
geos::geom::util::GeometryEditor::editPolygon(geos::geom::Polygon const*,
geos::geom::util::GeometryEditorOperation*) (GeometryEditor.cpp:117)
==19845== by 0xF212273:
geos::geom::util::GeometryEditor::edit(geos::geom::Geometry const*,
geos::geom::util::GeometryEditorOperation*) (GeometryEditor.cpp:88)
==19845== by 0xBFB30FE:
geoc::alg::VertexSnapper::snapVertices(geoc::geo::GEOCGeom*,
geos::geom::CoordinateSequence*) (in
/host/Users/Tereza/Documents/CVUT-FSv/BP/src/geoc_cpp/libgeoc.so.1.0.0)
==19845== by 0xBFB33A1: geoc::alg::VertexSnapper::snap() (in
==19845== by 0x566782E: QgsConflateProvider::vertexSnap() (in
/host/Users/Tereza/Documents/CVUT-FSv/BP/src/qgsconflate/libqgsconflate.so.1.0.0)
==19845== by 0x401C65: main (main.cpp:85)
==19845== 192 bytes in 3 blocks are possibly lost in loss record 347 of 426
==19845== by 0xF206ACA:
geos::geom::GeometryFactory::createPolygon(geos::geom::LinearRing*,
std::vector<geos::geom::Geometry*, std::allocator<geos::geom::Geometry*>
>*) const (GeometryFactory.cpp:525)
==19845== by 0xF212568:
geos::geom::util::GeometryEditorOperation*) (GeometryEditor.cpp:144)
==19845== 408 bytes in 3 blocks are possibly lost in loss record 382 of 426
==19845== by 0xF1FABE5:
geos::geom::CoordinateArraySequence::CoordinateArraySequence(geos::geom::CoordinateArraySequence
const&) (new_allocator.h:92)
==19845== by 0xF1FACD8: geos::geom::CoordinateArraySequence::clone()
const (CoordinateArraySequence.cpp:77)
==19845== by 0xBFB7B6C:
geoc::edit::VertexGeometryEditorOperation::edit(geos::geom::CoordinateSequence
const*, geos::geom::Geometry const*) (in
==19845== by 0xF211A26:
geos::geom::GeometryFactory const*) (CoordinateOperation.cpp:36)
Anybody knows how to fix that?
Thanks,
Tereza
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130508/36fe3e97/attachment.html>
