[geos-devel] using CoordinateOperation::edit cause memory leaks
Tereza Fiedlerová
tfiedlerova at gmail.com
Wed May 15 13:42:08 PDT 2013
2013/5/13 Sandro Santilli <strk at keybit.net>:
> Hi Tereza, could you include a full testcase, including caller ?
> --strk;
I tried to make it easier, but I see it wasn't good idea, so I'm
giving here the necessary code without changes:
vertexgeometryeditoroperation.h
#ifndef VERTEXGEOMETRYEDITOROPERATION_H
#define VERTEXGEOMETRYEDITOROPERATION_H
// GEOS includes
#include <geos/geom/CoordinateSequence.h>
#include <geos/geom/Geometry.h>
#include <geos/geom/util/CoordinateOperation.h>
#include <geos/geom/CoordinateSequenceFactory.h>
// local includes
#include "geoc.h"
#include <QtGui>
using namespace std;
using namespace geos;
using namespace geos::geom;
using namespace geos::geom::util;
using namespace geoc;
using namespace geoc::geo;
using namespace geoc::alg;
using namespace geoc::edit;
namespace geoc {
namespace edit {
/** Class for editing geometry - snap vertices to the closest points. */
class VertexGeometryEditorOperation: public CoordinateOperation
using CoordinateOperation::edit;
public:
/// Constructor
VertexGeometryEditorOperation( ): closeCoord(NULL),
tolDistance(0), changed(false){}
/** Set private closeCoord to given coord.
void setCloseCoordSeq( CoordinateSequence *coord ) { closeCoord = coord; }
/** Set tolerance distance
void setTolDistance( double tol ) { tolDistance = tol; }
/** Return true if geometry was changed
bool isChanged() { return changed; }
/** Virtual function for editing geometry - snap to closest vertices.
* @param coordinates Not important.
* @param gGeometry to be edited.
CoordinateSequence* edit(const CoordinateSequence *coordinates,
const Geometry *g );
private:
CoordinateSequence *closeCoord;
double tolDistance;
bool changed;
} //namespace geoc
} //namespace edit
#endif // VERTEXGEOMETRYEDITOROPERATION_H
vertexgeometryoperation.cpp
#include "vertexgeometryeditoroperation.h"
namespace geoc {
namespace edit {
CoordinateSequence* VertexGeometryEditorOperation::edit(const
CoordinateSequence *, const Geometry *geom )
CoordinateSequence* coord = geom->getCoordinates();
// find closest point from closeCoord
for ( size_t i = 0; i < coord->getSize(); i++)
// minimal distance
double minDist = tolDistance;
size_t indMin = 0;
bool isMin = false;
for ( size_t j = 0; j < closeCoord->getSize(); j++ )
// compute distance between two tested points
double dist = coord->getAt(i).distance( closeCoord->getAt(j) );
if( (0 < dist) && (dist < minDist) )
minDist = dist;
indMin = j;
isMin = true;
// set new coordinate to the closest point if there is some
if ( isMin )
coord->setAt( closeCoord->getAt(indMin), i );
changed = true;
return coord;
} //namespace geoc
} //namespace edit
function using code above
void VertexSnapper::snapVertices(Geometry *geom, CoordinateSequence *closeCoord)
// create and set geometry editor
VertexGeometryEditorOperation myOp;
myOp.setCloseCoordSeq( closeCoord );
myOp.setTolDistance( tolDistance );
GeometryEditor geomEdit( geom->getFactory() );
// set geometry to edited one
geom=( geomEdit.edit( geom , &myOp ) );
Thanks for help in advance,
Tereza
