[geos-devel] Looking for 3.4 to use the Delauny Triangles
Stephen Woodbridge
woodbri at swoodbridge.com
Thu May 23 08:06:37 PDT 2013
On 5/23/2013 10:50 AM, Olivier Courtin wrote:
> On May 23, 2013, at 4:41 PM, Stephen Woodbridge wrote:
> Hi Stephen,
>> sh: Can't open ./tools/svn_repo_revision.sh
> You need to create it manually before launching make step,
> Cf: http://trac.osgeo.org/geos/wiki/BuildingOnUnixWithCMake
> Dunno, really why this step was added...
Thanks for the pointer Olivier.
Well, it defeats the whole usefulness of generating nightly snapshots.
The script that generates the snapshots should be updated to create
geos_svn_revision.h or a dummy svn_repo_revision.sh with the version of
the snapshot hard coded in it before creating the tarball. Since the
snapshot is NOT an svn working copy there is NO way to get the svn info
version number to accurately create the file. Which means you have to
checkout the respository to be able to build it.
Thanks,
-Steve
