[geos-devel] [GEOS] #674: VoronoiDiagramBuilder uses fmax which breaks MSVC11 build
GEOS geos-trac at osgeo.org
Tue Nov 19 03:03:31 PST 2013
 Reporter:  Twiddeldidu  |       Owner:  geos-devel@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  3.4.3
Component:  Default      |     Version:  svn-trunk
 Severity:  Unassigned   |    Keywords:  msvc
 The build configuration already has defined NOMINMAX in the CMakeLists.txt
 but there is still a compiling issue with msvc11 (x64) and CMake.
 elseif(MSVC)
   # Set pedantic mode by default
   #set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /W4")
   string(REGEX REPLACE "/W[0-9]" "/W4" CMAKE_CXX_FLAGS
 "${CMAKE_CXX_FLAGS}")
   if(MSVC80 OR MSVC90 OR MSVC10 OR MSVC11)
     # Option is to enable the /MP switch for Visual Studio 2005 or later
     option(GEOS_MSVC_ENABLE_MP
       "Set to ON to build GEOS with the /MP option (Visual Studio 2005 and
 above)." ON)
     mark_as_advanced(GEOS_MSVC_ENABLE_MP)
     if(GEOS_MSVC_ENABLE_MP)
       set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /MP")
     endif()
     message(STATUS "Setting Visual Studio 2005+ option /MP to
 ${GEOS_MSVC_ENABLE_MP}")
     add_definitions(-D_SCL_SECURE_NO_WARNINGS)
     add_definitions(-D_CRT_SECURE_NO_WARNINGS)
 ==     add_definitions(-DNOMINMAX) ==
   endif()
 endif()
 There is a problem with '''VoronoiDiagramBuilder.cpp''' because it uses
 fmax. I made a quick patch changing this to the generic std::max instead
 of using fmax.
Ticket URL: <http://trac.osgeo.org/geos/ticket/674>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
