[geos-devel] help compiling windows library
Riccardo Cohen r.cohen at realty-property.com
Thu Nov 21 23:06:59 PST 2013
Thanks Mateusz  Loskot
I've double checked it and triple checked it when looking for a
solution. I ran autogen.bat (which seems to be unnecessary since all
headers are provided in tar.bz package) but it did not change. I did not
run svn_repo_revision.sh since I did not download from svn, and the
geos_svn_revision.h is present.
All compilation went all right, only linking seems to fail. Is there any
additional option to set in nmake command to show more errors and line
numbers, I could not find any (I'm not using nmake very often).
Thanks
On 21/11/13 21:30, Mateusz Loskot wrote:
> On 21 November 2013 17:35, Riccardo Cohen <r.cohen at realty-property.com> wrote:
>> Hello
>> I try to compile Geos on windows 7 with nmake (I have visual studio 2010)
>> I did the following :
>> - download   geos-3.4.2.tar.bz2  package from http://trac.osgeo.org/geos/
>> - unzip
>> - run following command :
> Please, double check you follow the instructions as specified here
> http://trac.osgeo.org/geos/wiki/BuildingOnWindowsWithNMake
> Best regards,
Riccardo Cohen
+33 (0)6 09 83 64 49
Société Realty-Property.com
16 rue de Belle Isle
37100 Tours
France
<http://www.appartement-maison.fr>
