[geos-devel] Not all files are cleaned
Frank Warmerdam
warmerdam at pobox.com
Thu Oct 3 10:42:42 PDT 2013
FYI,
I think geos tickets should be filed at:
http://trac.osgeo.org/geos/
Best regards
Frank
On Thu, Oct 3, 2013 at 10:09 AM, Sandro Santilli <strk at keybit.net> wrote:
> Hi Paul,
> On Thu, Oct 03, 2013 at 06:33:30PM +0200, Paul Meems wrote:
>> I build on Win7 with nmake in a VS2008 prompt.
>> During this I get an error because the 'clean' doesn't delete the obj-files
>> in the capi folder.
>> I'm using GEOS v3.4.2
> It will get fixed if you attach a patch to a ticket:
> http://trac.osgeo.org/osgeo
> If you can't provide a patch, a ticket is still worth it
> (although I don't know if any developer uses nmake, I don't)
> --strk;
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
and watch the world go round - Rush | Geospatial Software Developer
