[geos-devel] Not all files are cleaned
Paul Meems
bontepaarden at gmail.com
Fri Oct 4 00:16:29 PDT 2013
Thanks Frank and Sandro.
I've filled a ticket: #667 (http://trac.osgeo.org/geos/ticket/667)
BTW. I don't think this is a nmake issue but an issue in the makefile.vc
Paul
*Paul Meems *
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org
Owner of MapWindow.nl - Support for
Dutch speaking users.
www.mapwindow.nl
2013/10/3 Frank Warmerdam <warmerdam at pobox.com>
> FYI,
> I think geos tickets should be filed at:
> Best regards
> Frank
> On Thu, Oct 3, 2013 at 10:09 AM, Sandro Santilli <strk at keybit.net> wrote:
> > Hi Paul,
> > On Thu, Oct 03, 2013 at 06:33:30PM +0200, Paul Meems wrote:
> >> I build on Win7 with nmake in a VS2008 prompt.
> >> During this I get an error because the 'clean' doesn't delete the
> obj-files
> >> in the capi folder.
> >> I'm using GEOS v3.4.2
> > It will get fixed if you attach a patch to a ticket:
> > http://trac.osgeo.org/osgeo
> > If you can't provide a patch, a ticket is still worth it
> > (although I don't know if any developer uses nmake, I don't)
> > --strk;
> > geos-devel mailing list
> > geos-devel at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geos-devel
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20131004/2f2054f1/attachment.html>
