[geos-devel] [GEOS] #600: [JTS works] TopologyException in ST_Union with valid geometries
GEOS geos-trac at osgeo.org
Wed Oct 16 00:16:20 PDT 2013
 Reporter:  ppawel      |        Owner:  geos-devel@…
     Type:  defect      |       Status:  closed
 Priority:  major       |    Milestone:  3.5.0
Component:  Default     |      Version:  3.3.6
 Severity:  Unassigned  |   Resolution:  fixed
 Keywords:              |
Changes (by strk):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I cannot reproduce here with POSTGIS="2.1.1dev r12013" GEOS="3.4.3dev-
 CAPI-1.8.3 r3958"
 Assuming fixed by 3.3.something (tried 3.3.9?) -- reopen if you cannot
 confirm
Ticket URL: <http://trac.osgeo.org/geos/ticket/600#comment:6>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
