[geos-devel] GEOS Usage
Greg Troxel
gdt at ir.bbn.com
Wed Oct 16 15:51:20 PDT 2013
Howard Butler <howard at hobu.co> writes:
You make a good point that a BSD-licensed geos equivalent would be
useful to those who wish to create proprietary derived works.
> That this community is hostile to contribution from organizations such
> as yours is an opportunity.
As I read the mail, people simply pointed out that the geos license
(which can only be changed by agreement of *all* of the copyright
holders) and the app store terms are inconsistent, so the notion of
using geos in an iOS program and distributing it through Apple simply
does not work. I don't think this is hostile, but just a calm
recognition of how the geos and Apple license terms interact.
Specifically, I haven't seen any contributions rejected.
Given that, can you explain what you mean by "hostile to contribution"?
> Maybe you could get ESRI to release the C++ library on which
> https://github.com/Esri/geometry-api-java is ported from under the
> same Apache license :)
Indeed, that could on someone's TODO list, along with getting Apple to
have app store terms that are consistent with the GPL :-)
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20131016/b7fe14b1/attachment.pgp>
