[geos-devel] [GEOS] #626: Intersection with result from intersection --> TopologyException Error
geos-trac at osgeo.org
Fri Sep 6 13:37:21 PDT 2013
Reporter: rajanski | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.3.9
Component: Default | Version: 3.3.3
Severity: Significant | Resolution: fixed
Keywords: intersection, st_intersection, topology exception |
Changes (by strk):
* cc: geosbug@… (added)
* status: new => closed
* resolution: => fixed
* milestone: => 3.3.9
Comment:
Just tested this, works fine with 3.3.9.
Ticket URL: <http://trac.osgeo.org/geos/ticket/626#comment:7>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
