[geos-devel] Weekly Report 12- Adding Voronoi Diagram to GEOS
vishal tiwari
hi.vishal123 at gmail.com
Sat Sep 7 12:37:57 PDT 2013
Week 12 report is as follows:
<http://trac.osgeo.org/geos/wiki/Reports#Week12:>
*1. Work Done:*
- Ported the following classes:
-- triangulate::Segment.[1]
-- triangulate::splitSegment.[2]
-- triangulate::NonEncroachingSplitPointFinder.[3]
-- triangulate::ConstraintSplitPointFinder.[3]
-- (method)geom::LineSegment::getCoordinate().[3]
- Worked out a number of problems with strk such as memory leaks in the
triangulate::quadedge::QuadEdgeSubdivision class which is required for
Voronoi Diagram Builder.[4]
*2. Problems Faced:*
- Had some problems in fixing the memory leaks.
*3. Work to be done in the next week*
- Test VoronoiDiagramBuilder for memory leaks.
- Make documentation.
Branches:
[1]https://github.com/vishaltiwari/libgeos/tree/Segment,
[2]https://github.com/vishaltiwari/libgeos/tree/SplitSegment,
[3]
https://github.com/vishaltiwari/libgeos/tree/NonEncroachingSplitPointFinder
[4]https://github.com/vishaltiwari/libgeos/tree/QuadEdgeSubdivision_mark2
wiki:
http://trac.osgeo.org/geos/wiki/GSoC
Thanks and kind regards,
Vishal Tiwari
Undergraduate
Computer Science and Engineering
Lab for Spatial Informatics
IIIT-Hyderabad
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130908/82f77452/attachment.html>
