[geos-devel] [GEOS] #713: [Patch] Add GeometryPrecisionReducer to C API
geos-trac at osgeo.org
Mon Dec 15 07:41:13 PST 2014
Reporter: smani | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.4.3
Component: Default | Version: 3.4.2
Severity: Unassigned | Keywords:
Comment(by smani):
Yes indeed the geometry returned by GeometryPrecisionReducer::reduce
retains the GeometryFactory of the input geometry.
The API you describe basically means exposing the GeometryFactory in the C
API, along with methods to create a GeometryFactory with a given
PrecisionModel, and then adding methods for all geometry types to create
them with the specified GeometryFactory, right?
But considering a situation where the geometry is already given, exposing
the GeometryPrecisionReducer would still be needed, since AFAICS it is the
only way to reduce the precision of an already given geometry?
Ticket URL: <http://trac.osgeo.org/geos/ticket/713#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
