[geos-devel] [GEOS] #682: ST_OffsetCurve fails for some geometries
geos-trac at osgeo.org
Tue Feb 4 01:47:05 PST 2014
Reporter: jventin | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.4.3
Component: Default | Version: 3.4.2
Severity: Unassigned | Keywords:
Comment(by jventin):
It should be added that I have encountered this problem only with
polygons. When switching start and end point for the geometries causing
errors, it seems that the offset function will give a result (not error).
Ticket URL: <http://trac.osgeo.org/geos/ticket/682#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
