[geos-devel] Exposing Precision model through C-API
Varun Saraf
varunsaraf14 at gmail.com
Wed Feb 19 06:21:48 PST 2014
On Mon, Feb 17, 2014 at 8:29 PM, Varun Saraf <varunsaraf14 at gmail.com> wrote:
> On Mon, Feb 17, 2014 at 5:10 PM, Sandro Santilli <strk at keybit.net> wrote:
>> On Mon, Feb 17, 2014 at 03:53:29PM +0530, Varun Saraf wrote:
>> > Hi,
>> > I am not sure if I have understood the solution, but this is what I
>> think.
>> > For exposing PrecisionModel through the C-API, we need to write a
>> function
>> > in the geos_ts_c.cpp file which takes the required arguments for the
>> > precision model. It constructs a new GeometryFactory with appropriate
>> > arguments which in turn calls PrecisionModel with those arguments.
>> What needs to be done is really to be decided, and deciding that is
>> part of the task. You should make an RFC document and sollicit comments
>> from this mailing list until some kind of consensus is found, basically.
>> Note that anything you construct in that function needs to have a way
>> to be destroyed.
>> > My doubt is what all arguments need to be passed to this C-API function
>> and
>> > is that what we are supposed to design. Also we will have to make
>> > appropriate changes to the GeometryFactory constructor.
>> I don't think any change in the C++ interface is required.
Any suggestions?
> Consider this for an example. We want to create a precision model using
> the C-API using the following arguments [1] PrecisionModel (double
> newScale, double newOffsetX, double newOffsetY). Now the wrapper calls [2]
> GeometryFactory with these arguments but it has no constructor to accept
> them. Or is it that GeometryFactory need not be called at all and the
> wrapper directly calls existing PrecisionModel interface. Please clarify.
> Regards,
> Varun Saraf
> [1] http://geos.osgeo.org/doxygen/classgeos_1_1geom_1_1PrecisionModel.html
> [2]
> http://geos.osgeo.org/doxygen/classgeos_1_1geom_1_1GeometryFactory.html
>> > Please tell me if I am in the right direction.
>> Yes, I think you are.
>> --strk;
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20140219/c14d606e/attachment.html>
