[geos-devel] regarding GEOS C++ API in ThirdParty
    Rashad M
    mohammedrashadkm at gmail.com
    Thu Jul  3 00:56:43 PDT 2014
Hi all,
I have some questions regarding GEOS C++ API.  From readme[1],
 GEOS C++ API is deprecated and not recommended for use in third party
libraries. But most of examples and test are still in C++ and C++ api still
exists and used in tests. The reason for this is goes itself can use c++
interface but I want to is that the only reason for keeping c++ interface?
If a third party already uses C++ interface is it recommended to move to C
API?
Lastly if there is a migration guide that must be read before changing to C
API?
[1] https://github.com/libgeos/libgeos
The C libary uses the C++ interface, but the
C library follows normal ABI-change-sensitive versioning, so programs
that link only against the C library should work without relinking
when geos is upgraded.)
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20140703/0c797eb7/attachment.html>
