[geos-devel] [GEOS] #693: Buffer operation uses excessive amount of memory
geos-trac at osgeo.org
Mon Jun 9 07:54:15 PDT 2014
Reporter: wonder | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.4.3
Component: Default | Version: 3.4.2
Severity: Unassigned | Keywords:
When doing a buffer operation on a more complex linestring, the memory
consumption rises to many hundreds of megabytes, eventually exhausting RAM
and locking up the system completely.
SAGA builds the same buffer with very low memory usage.
Please see the attached example code for a reproducible example.
Originally reported in QGIS: http://hub.qgis.org/issues/10356
Ticket URL: <http://trac.osgeo.org/geos/ticket/693>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
