[geos-devel] [GEOS] #694: PreparedPoint::intersects gives different results from Point::intersects
GEOS geos-trac at osgeo.org
Mon Jun 30 13:13:31 PDT 2014
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  3.4.3
Component:  Default     |     Version:  3.4.2
 Severity:  Unassigned  |    Keywords:
Changes (by strk):
  * version:  svn-trunk => 3.4.2
  * milestone:  3.5.0 => 3.4.3
Comment:
 Interesting enough, it looks like tests for prepared predicates are
 completely missing, see
 http://trac.osgeo.org/geos/browser/tags/3.4.2/tests/xmltester/tests/general/MISSING
 Sounds about time to port those tests!
 Assuming the bug is also in 3.4.3 (and would probably also be in 3.3.9)
Ticket URL: <http://trac.osgeo.org/geos/ticket/694#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
