[geos-devel] Exposing Precision model through C-API
Varun Saraf varunsaraf14 at gmail.com
Wed Mar 12 06:16:15 PDT 2014
So I guess we just document the issue and leave it at that. On a side note,
when the geometry becomes broken on deleting its geometry factory, what are
the side effects. I mean to ask does it not affect much if the geometry's
geometry factory pointer points to NULL or the user has to specifically
keep this in mind and ensure this situation never arises.
Also, how should I go forward from here?
Regards,
Varun Saraf
On Wed, Mar 12, 2014 at 6:16 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Wed, Mar 12, 2014 at 06:16:00AM -0400, Paul Ramsey wrote:
> > I would tend to expect choosing a single precision model and working
> > with it for a long time to be a more common usage than swapping
> > between lots of models. My bias.
> I also find this to be a more likely usecase.
> --strk;
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20140312/31421d3c/attachment-0001.html>
