[geos-devel] [GEOS] #686: cmath needed for two tests
    geos-trac at osgeo.org
    Fri Mar 14 15:52:09 PDT 2014
 Reporter:  goatbar     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.4.3
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
 Could someone be so kind as to add
 #include <cmath>
 to these two files?  We have a picky compiler demanding cmath for the
 proper definition of ISNAN.
   * tests/unit/geom/CoordinateArraySequenceTest.cpp
   * tests/unit/io/WKBWriterTest.cpp
Ticket URL: <http://trac.osgeo.org/geos/ticket/686>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
