[geos-devel] concave hull
Mike Toews mwtoews at gmail.com
Sun Mar 16 14:01:23 PDT 2014
On 10 March 2014 00:36, Riccardo Cohen <r.cohen at realty-property.com> wrote:
> I need to generate a concave hull for a collection of points. I found only
> convexHull() in Geos 3.5.0.
> But it seems that PostGis uses some GEOS functions to make a concave hull :
> http://postgis.net/docs/ST_ConcaveHull.html
> Is it possible simply in a C program without having to implement a special
> new algorithm ?
> Thanks a lot
No C library function is available for ConcaveHull. The algorithm is
implemented in PL/pgSQL:
http://trac.osgeo.org/postgis/browser/trunk/postgis/postgis.sql.in#L5098
The code could probably be adapted to a somewhat lengthy C routine,
which would call several GEOS functions. However, some of the
underlying functions found in the algorithm are not available through
GEOS, such as:
 * ST_Translate, since there are oddly no affine transformation
   abilities with GEOS
 * ST_ForceSFS, which is part of liblwgeom
-Mike
