[geos-devel] MinGW build of Geos on Win7
Sandro Santilli
strk at keybit.net
Tue Nov 4 09:46:55 PST 2014
On Tue, Nov 04, 2014 at 07:26:48PM +0200, Theuns Heydenrych wrote:
> Thanks, I can give that a try.
> One other thing I have noticed is that other projects that uses the same
> tool chain, have no problems regarding this. (trailing ' character)
> I checked the libtool version with libtool --version and geos libtool
> version is 2.2.6 while the other is 2.4
> The other projects is freexl, libiconv, libxml2 and gsl.
> Maybe the libtool version for geos is too old?
> But how to get a newer version into geos?
You should be able to copy the libtool script from the other projects,
or (probably better) run the ./autogen.sh script if it comes with
the source tarball.
What version of GEOS are you trying to build, btw ?
--strk;
