[geos-devel] [GEOS] #509: GEOS crashes on check in MingW GCC 4.6.2
geos-trac at osgeo.org
Wed Nov 26 07:35:08 PST 2014
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.3.4
Component: Default | Version: 3.3.3
Severity: Unassigned | Resolution: wontfix
Keywords: |
Comment(by mloskot):
FYI, r4037 solves the following test failure for me, on Windows with
VS2013, which @dustymugs also reported:
group: capi::GEOSisValidDetail, test: test<3>
problem: assertion failed
Ticket URL: <http://trac.osgeo.org/geos/ticket/509#comment:9>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
