[geos-devel] Buffering of invalid polygon seems to produce a less useable result
Casper Børgesen (CABO) CABO at NIRAS.DK
Wed Oct 1 23:16:58 PDT 2014
Hi Sandro.
Thank you for your answer. As far as I have checked, I'm starting out with valid geometries only. So if valid inputs guarantees valid output, I guess I have to go bug hunting.
Regards, Casper
-----Original Message-----
From: geos-devel-bounces at lists.osgeo.org [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Sandro Santilli
Sent: 1. oktober 2014 16:56
To: GEOS Development List
Subject: Re: [geos-devel] Buffering of invalid polygon seems to produce a less useable result
On Mon, Sep 29, 2014 at 07:05:28PM +0000, Casper Børgesen (CABO) wrote:
> Are there any methods to better ensure validity of geometries
> resulting from the various geometric functions?
By contract, if the inputs are invalid, the output are not guaranteed not only to be valid but also to be computable.
A valid input should always result in a valid output, or it would be a bug.
Turning an invalid geometry to a valid one can be tricky, you may want to look at the ST_MakeValid funcition in PostGIS to see how it is implemented.
--strk;
 ()  ASCII ribbon campaign  --  Keep it simple !
 /\  http://strk.keybit.net/rants/ascii_mails.txt
geos-devel mailing list
geos-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geos-devel
