[geos-devel] Geos not compiling Ubuntu 12.0.4
Rémi Cura
remi.cura at gmail.com
Sun Oct 12 07:42:47 PDT 2014
Some update for the record:
fresh git clone compiles fine with classic autotools.
fresh git clone compiles fine with cmake
fresh git clone compiled with autotools then cmake (in a "build" directory
) compiles fine.
I think it's about using a vbox shared file system.
For the cmake way, you have to use the linux file system, no win shared
folder.
Thanks all for the advice !
Cheers,
Rémi-C
2014-10-11 21:04 GMT+02:00 Mateusz Łoskot <mateusz at loskot.net>:
> On 11 October 2014 18:06, Sandro Santilli <strk at keybit.net> wrote:
> > On Sat, Oct 11, 2014 at 05:44:28PM +0200, Mateusz Łoskot wrote:
> >> On 11 October 2014 16:05, Sandro Santilli <strk at keybit.net> wrote:
> >> > On Fri, Oct 10, 2014 at 09:35:23PM +0200, Mateusz Łoskot wrote:
> >> >> On 10 October 2014 18:38, Sandro Santilli <strk at keybit.net> wrote:
> >> >> > On Fri, Oct 10, 2014 at 06:01:30PM +0200, Rémi Cura wrote:
> >> >> >> I tried to compile geos with cmake :
> >> >> >> libgeos/capi/geos_c.cpp: In function ‘geos::geom::Geometry*
> >> >> >> GEOSClipByRect(const geos::geom::Geometry*, double, double,
> double,
> >> >> >> double)’:
> >> >> >> libgeos/capi/geos_c.cpp:491:64: error: ‘GEOSClipByRect_r’ was not
> declared
> >> > Uhm, then maybe geos_c.h was not regenerated ?
> >> There is a command in the root CMakeLists.txt for it, so it should be
> generated
> >> https://github.com/libgeos/libgeos/blob/svn-trunk/CMakeLists.txt#L305
> > Well, I tried building it myself but for me it fails as it tries to
> > build .cpp files that happen to be in the source dir but are not meant
> > to be built ...
> If there are .cpp files which are not meant to be compiled, then
> the CMake will grab them too, due to the globbing.
> That may be a problem, indeed.
> > Does it build for you ?
> I haven't tried, no Linux handy ATM.
> Best regards,
> Mateusz Łoskot, http://mateusz.loskot.net
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20141012/afd1175c/attachment.html>
