[geos-devel] [GEOS] #703: Empty.equals(Empty) == false
GEOS geos-trac at osgeo.org
Tue Sep 9 07:15:47 PDT 2014
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.4.3
Component:  Default     |     Version:  3.4.2
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 Same happens with Polygon empty. The common root is
 Envelope::equals(Envelope) returning false for the so-called "null
 envelope". Should it be true instead ?
Ticket URL: <http://trac.osgeo.org/geos/ticket/703#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
